Can i pull a 6 foot disc
   / Can i pull a 6 foot disc #1
ChadWS
Okla.
Framtrac 320DTC
I have a Farmtrac 32 hp tractor 4x4, R4 tires will it pull a 3pt 6 foot disc not sure of the brand of the disc,I need to disc about 2 acres to plant grass seed and I have cut all of the weeds down and would like to get grass seed planted a friend said i could use his disc .
   / Can i pull a 6 foot disc #2
Is this a single row or 2 row disc you want to pull. how many discs give us more information
It has 2 rows of disc not sure how many disc on each row,I have seen the disc looks heavy.my soil when wet sticks bad to my R4s
   / Can i pull a 6 foot disc #4
Chad,
My guess is then it would be about 16 discs. you would probably be able to pull it as long as you can control its depth to a couple of inches, Much deeper than 2" or 3" and i think you will struggle. Having said that 2" is fine for planting grass.
Good luck, and welcome aboard TBN /forums/images/graemlins/wink.gif
   / Can i pull a 6 foot disc #5
What part of Oklahoma you from?
Thanks i will go get it and try i have to go about 40 miles to get the disc didnt want to go get it then find out i couldnt use it.
I live in Noble south of Norman.
   / Can i pull a 6 foot disc #8
I pull a 10' John Deere disc with mine in low range and have no problems. If you're soil is wet (or even moist) make sure the disc scrapers are adjusted correctly before you begin.
   / Can i pull a 6 foot disc #9
I pulled a heavy old ford 6' dual ganged disc with my ex Nh 1920.. that is 32hp 4x4.. etc. I had sandy/grassy soil so i was weighting it down to get it to bite.. sounds like yours will bit good. I had no problems whatsoever pulling.. turning needed brakes sometimes though.. front weight will help that. Aso.. many disc's can be adjusted for more or less agressive bite.
Soundguy
   / Can i pull a 6 foot disc #10
</font><font color="blue" class="small">( I have a Farmtrac 32 hp tractor 4x4, R4 tires will it pull a 3pt 6 foot disc not sure of the brand of the disc,I need to disc about 2 acres to plant grass seed and I have cut all of the weeds down and would like to get grass seed planted a friend said i could use his disc . )</font>
Should be no problem. I pulled a 66" one (it has 16 16" discs) with my little TC29. I did have to use 4wd with the R4's, but traction was more a problem than power.
Wolverine Quick Attach 72" Bucket (A50514)
Wolverine Quick...
2018 CHEVROLET SILVERADO TRUCK (A51243)
2018 CHEVROLET...
Ingersoll Rand 2570 Skidloader Breaker (A50774)
Ingersoll Rand...
Stone Concrete Trowel (A47384)
Stone Concrete...
Chipper (A50774)
Chipper (A50774)
