Can I upgrade tires?
   / Can I upgrade tires? #1
andrewj
Platinum Member
South Carolina
JD 5105
Hi folks. Ihave a JD 5105. I have 14.9 by 28 rears, would like 16 by 28 rears whichis an available upgrade if buying new. Will the 16/28s fit on my wheel rims? thanks.
   / Can I upgrade tires? #2
I think the 16s are actually 16.9". I'm not sure about the rims. BobG in VA
how could I find out for sure?
   / Can I upgrade tires? #4
Suggest you ask the dealer, what the part number for the rims are for both the 14s and 16s. If its the same, guess what? BobG in VA
   / Can I upgrade tires? #5
Just a head's up, if this is a 4wd tractor the fronts & rears need to match, can't just change one axle.
--->Paul
   / Can I upgrade tires? #6
As you have a 5000 series tractor, and the 51-54 series are basicly the same tractor except for the engine, no problem. I changed mine for the 16.5 rear and changed the front to match. I have a 5300 and went to the 5400 size tires. Gave me a bit more clearance and traction. Used the same rims and haven't had a problem for 5 yrs.
KENWORTH T/A DAY CAB ROAD TRACTOR (A52706)
KENWORTH T/A DAY...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A54607)
2007 PETERBILT 379...
2025 SDLANCH DUMPER (A53843)
2025 SDLANCH...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2016 FORD F550 SUPER DUTY SERVICE TRUCK (A51406)
2016 FORD F550...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
