Can I use a cat 0 attach on a cat I tractor???
   / Can I use a cat 0 attach on a cat I tractor??? #1
Tororider
Veteran Member
SE Michigan
JD 4310
I was wondering if this is possible, and if not, how hard it would be to modify so that it is possible? Thanks
   / Can I use a cat 0 attach on a cat I tractor??? #2
Sure - the pins on the cat 0 will be too small for your cat 1 hitch, but you just put spacers (sleeves) in. You can find them at tractor supply stores and some hardware stores.
Bear in mind that the cat 0 implement was designed for much less horsepower than your bigger tractor. You will be able to destroy it - it is kind of like running a speaker with a much bigger amplifier than it was designed for. It'll work just fine until you put in too much power and then it frys.
   / Can I use a cat 0 attach on a cat I tractor??? #4
Not precisely the same, but a couple of tractors ago I traded a Cat 1 for a Cat 2. Wasn't long before I pretzled two of the implements that I'd been using with the previous Cat 1 tractor. I fixed them up best I could, and traded up to Cat 2 replacements. No problems since.
It's a simple matter of the right tool for the job. Depending upon what type implements you're talking about, yours could end up pretzled too.
//greg//
   / Can I use a cat 0 attach on a cat I tractor??? #5
When you think CAT "0" , think about small lawn tractors and ATVs.
I saw a 48" CAT 0 box-scraper online recently, and noticed, the shipping weight was only 140 lbs. That pretty weak, no, that's really weak!
You could use bushings, easy enough, but, better be very gentle.
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
2022 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A52472)
2022 ALLIANCE...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2019 MITSUBISHI OUTLANDER SPORT (A52472)
2019 MITSUBISHI...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
