Can you identify this RB and it is worth $175?
   / Can you identify this RB and it is worth $175? #1
HunterWare
Bronze Member
VA
JD 1026R
I found this on Craigslist and I thought I'd run it by the experts before I trot over to take a look at it... Thanks =)
   / Can you identify this RB and it is worth $175? #2
YES!! Definitely worth $175 if it's a CAT 1 implement. Can't tell what brand it is but for $175 you can't go too wrong no matter who made it. One caveat though, make sure it is CAT 1 size, if it's a CAT 0, then you might want to pass on it. That would be up to you though.
   / Can you identify this RB and it is worth $175? #3
It apparently has the ability to be off set, given that slot along the backside.
That feature alone is pretty darn cool. If it's close, go put your eyes on it. See if the cutting blade is worn and whether it is reversible.
   / Can you identify this RB and it is worth $175? #4
Heck Yeah ! Its worth 175 bucks. As long as your gonna use it more than once.
   / Can you identify this RB and it is worth $175? #5
Yes, it may not be the heaviest out there, but would work fine for pushing snow.
I was actually hoping for something to use behind my 2305 for dirt road leveling and grading, some field work, and some snow work too. Sounds like it's not the right one for me?
   / Can you identify this RB and it is worth $175? #7
The jury is going to find you guilty of over thinking. :laughing:
It would be fine for your 2305. The beauty of these finds is that if you don't like it down the road, or your needs change, you have so little in it you often make a buck in re-sale as opposed to taking a bath on buying new stuff.
The only reason to reject this might be if you find, when you get there, that it was designed for a tractor much, much taller than your 2305, which seems doubtful. You also know that you can likely get this for $150 cash offer. Another day of procrastination and it will be gone.
2015 Ford Fusion Sedan (A44572)
2015 Ford Fusion...
2015 Ford F-150 Ext. Cab Pickup Truck (A44572)
2015 Ford F-150...
2021 Ford F-150 4x4 Pickup Truck, VIN # 1FTFW1ED4MFA75491 (A44391)
2021 Ford F-150...
2015 Ford Fusion...
3pt Hookup Auger (A44391)
3pt Hookup Auger...
SeaDoo Challenger 2000 20ft Jet Boat with Boat Trailer (A44572)
SeaDoo Challenger...
