Cannot disengage 4WD
/ Cannot disengage 4WD #1
Smalljobs
Massachusetts
Jinma 284
My 284 seems to be stuck in 4WD. Periodically I would engage or disengage it but it's been in 4WD for months now while I did a lot of work in the woods, mud, etc. In the past, I knew I had to disengage while moving or maybe turning a bit right and left, etc to free up the drive train.
I always had to pull the lever away from the transmission case before I could rotate it in/out of 4WD. Now the lever seems stuck in the case (rust?) and I can't move it outward. Maybe some Liquid Wrench etc.?
Has anyone come across this?
PS: This machine is almost never on any blacktop.
/ Cannot disengage 4WD #2
Jack up the front end until both front tires are off the ground. That works for me.
Pat
Pat - tks. I already tried that with no luck.
I placed a pry bar behind the lever and tried gently to coax it outward away from the transmission. It won't budge. I think maybe it's rusted.
/ Cannot disengage 4WD #4
Try some taps with a hammer or some heat and some WD40 or other penetrating oil.
Chris
Chris - That seems to be my plan and I want to be careful about thermally damaging any seal on that shaft. I think if I carefully heat the shaft, apply WD-40, and tap.....carefully, it should loosen up.
/ Cannot disengage 4WD #6
I would pull that top cover off first. Only 8 bolts. I have had mine off a few times, once when adding a dip stick/fill to the creeper box.
Chris
/ Cannot disengage 4WD #7
drive it around for 5 minites to warm up the transmition and front end. While still warm drain both front end and transmition fluid into a clean plastic container, drag a clean magnet through it and check for any particals. Now fill transmition and front end with diesel and drive around for another 5 minites , changeing gears, hi/lo, fwd and reverse. This will clean out any gunk that may be sticking in there. (this should have been done while RUNNING in the tractor).
Now drain the diesel out of the front end and transmition and refill with clean 90 wieght gear oil.
I hope that this has fixed your problem, if it has then your tractor probly was not run in properly and you may want to do this to your power steering and hydrolic (but replace the diesel with hydrolic fluid). And then also maybe your injector pump should be done before gunk makes it stick wide open (not fun when that happens) when I did that to my injector pump I refilled it with 5w40 motor oil.
/ Cannot disengage 4WD #8
Chris
This would probably be my next step also... It comes right off:)
/ Cannot disengage 4WD #9
Often this problem is merely the "detent ball" on the 4 wheel drive shift lever has rusted in place due to lack of movement. Liberally spray the detent ball on the shift lever (between shift lever and side of transmission case) with a rust penetrant, and maybe need to "tap" lightly on the shift lever (straight in toward transmission) to loosen the detent ball and get it to spring into the lever again, allowing the lever to move.
This machine was properly dealer prepped before delivery and I followed all the rules after that including fluid changing, cylinder head retorque, frequent oil change (fuel pump oil, too) chassis lube, etc. Now I have almost 400 trouble free hours.
Winter coming with plenty of snow plowing planned so I'm glad it's not the opposite problem. I'll try the WD-40 and tapping for now and tackle any remaining problem in the springtime.
Thanks to all.
By the way, follow my other thread on the backhoe thumb. Will have more to report on my new thumb soon :)
/ Cannot disengage 4WD #11
My 224 wants to get stuck in 4 often. I just put pressure on the lever while releasing the clutch and it goes in (or out) every time. I can do the same thing releasing the clutch to reverse too. Try it.
I'm pretty sure the shaft is frozen and the problem is not inside.
/ Cannot disengage 4WD #13
If you have a slope nearby try neutral while slowly rolling downhill. Put a little pressure on the lever, let off apply again. Might even try it backwards.
/ Cannot disengage 4WD #14
I have a landini ghibli 90 that will not disengage. The 4x4 lamp button will go out but not the one on the dash showing that it is still engaged and it is still in 4 wd.
/ Cannot disengage 4WD #15
welcome to TBN...
This is an old thread, perhaps nobody is watching it at the moment.
Might start a new thread for your specific concern if no answer from this thread.
suggest put tractor name in title so it catches people's eye....
Am unfamiliar with your tractor, thus cannot offer ideas other than typical debug/analysis ideas...such as wondering if perhaps the sensor is bad, thus giving you a false positive light.
My problem turned out to be exactly what I thought: The shaft passing from the inside of the case to the exterior control lever was rusted. I carefully used a solvent, Bernzo-Matic, and gently working the 2WD/4WD lever until it freed itself. Now I keep it oiled and cycle it often.
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
TROY-BILT GENERATOR (A64553)
TROY-BILT...
1997 Ford Expedition 4X4 SUV (A64557)
1997 Ford...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
2018 Autocar ACX Xpeditor T/A New Way Side Loader Garbage Truck (A64556)
2018 Autocar ACX...
1992 Polar 307 SS T/A Insulated Chemical Tanker Trailer (A64194)
1992 Polar 307 SS...
