Buying Advice Cannot find Ag whells for my 1620
   / Cannot find Ag whells for my 1620 #1
CSL112263
Attica, N.Y.
New Holland 1620
I am now having the same problem with my 1620 as I had with my 1220. i.e, I cannot fine used or after market ag wheels to replace the turf tires/wheels that came with it. I have exhausted all local options excepting the New Holland store which is prohibitively expensive. On the 1220, I eventually found a pair of r-4's that fit the rear turf rims but never did find the Ag rims I really wanted. Any ideas??
   / Cannot find Ag whells for my 1620 #4
Try West Kentucky Tractor 800-564-0567 I found a set (Ag )to fit my 1720 there
Many thanks!
   / Cannot find Ag whells for my 1620 #7
Good morning. Not sure if they will fit, but I have a set of ag rims from a NH TC29. I know they will fit most of the machines in the TC series up to about a TC33. Not sure if they will fit your 1620. Tires on them are no good. Rims are fine, but could use a paint job if you are picky about appearance. We're a long way away (I'm in SC). 400 bucks will buy all 4 of them if you have a way to pick them up.
I copied / pasted I sent to a tire dearler to give you the info on the wheels / turf tires presently on the 1620:
Thank you for responding to my inquiry. Per the owner's manual, the turf tires are:
Front - 25-8.50-14 4PR
Rear - 13.6-16,R3, 4PR
The rims, both front and rear have 6 bolts
Per my measurements:
On the rear rims, the space between the bolts is 7" and the center holr is 4.5"
On the front rims, the bolts are 4 3/4 " apart and the center hole is 3 1/16-1/8"
This is what I copied off the tires themselves:
Front - 25 x 8.5o - 14
Rears - 13.6 x 16 on 12" rims
For R-1 / Ag tires, the anual says:
Front - 7-14 R1 4PR
Rears - 11.2 x 24 R1 4PR
Again, I would prefer to get the r! / Ag rims and tires but I could be persuaded to go with the r4 industrials on the turf rims as an in between measure.
Thanks you
David Hoy Attica NY 14011
If they actually fit, perhaps we could ship them - thanks
   / Cannot find Ag whells for my 1620 #9
I'll measure tonight and let you know the hole sizes in the rims and bolt spacing. I know rears on that machine were 11.2 x 24 R1's so at least that matches.
   / Cannot find Ag whells for my 1620 #10
No go. Rear rims are 8 bolts. Pilot hole sizes are also quite different. Maybe someone else can use the rims. Good luck with yours.
2013 Ford F-150 (A50397)
2013 Ford F-150...
2004 Big Tex 10PI 18ft T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
2016 Chevrolet Camaro 1LT Coupe (A48082)
2016 Chevrolet...
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
