Can't grease roller bearing on Alamo flail.
   / Can't grease roller bearing on Alamo flail. #1
PatMcD
Maine
LS U5030
O.K., I have a Alamo SH88 flail mower I bought at an equipment auction last year. The rear roller was a little stiff so I bought new bearings and housings (Flailmaster cat # M-703976). On one of them, I just cannot get any grease into it at all. With the bearing out, I can shoot it in there easily, but with the bearing in place: no way. I can't find any difference between the 2 sides and why one would work and not the other. Any thoughts? Am I not putting the bearing back in the housing correctly (it drops in vertical then you roll it flat)?
   / Can't grease roller bearing on Alamo flail. #2
Some pictures might help those of us that haven’t worked on an Alamo flail.
Does the grease make it from the zerk into the bearing housing when the bearing isn’t installed?
   / Can't grease roller bearing on Alamo flail. #3
is the zerk passage in the housing open? some housings have a ring cut in them under the zerk, and the hole in the bearing needs to aligned with that ring,
I got it. Finally. Theres a little dimple on the outer raceway that needs to be lined up with the zerk, which means it had to be put in, what I thought was backwards.
74in FEL HD Round Back Bucket (A52748)
74in FEL HD Round...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
