Can't Level Craftsman Mower Deck: Help !!!
   / Can't Level Craftsman Mower Deck: Help !!! #1
bigcut
SC PA
Garden Tractor
My Sears Lawn Tractor (917.270820) was running and cutting fine. I decided to change out the blades on my 42" twin blade unit. To do this, I drove it up a couple of ramps to access the blades. I changed the blades out and noticed that one side of the mower deck was cutting lower than the other side. This wasn't a problem before I changed the blades. The left side of the mower deck front is an inch lower than the right side.
I reviewed the owners manual for adjustment and followed the adjustment procedures religiously. I loosened the nut under the arm to a maximum amount and tightened the nut on the opposite side in order to raise the right side of the deck....the end result is a difference of an inch between the 2 sides. Before starting this process, I checked tire pressure on a level surface, as well as the front links measurements as prescribed in the manual. This all checked out. (I've actually performed this process 3 times to make sure)
So is there something I did unknowingly to the deck in driving it up onto the ramps ? I'm baffled and frustrated at this point. Can't figure out what to do. Need one of you experts to help me out. What did I miss?
Thanks,
John
New Holland C185 (A47477)
New Holland C185...
MASTER FLOOR HEATER (A53843)
MASTER FLOOR...
2006 FONTAINE TRAILER CO. 48X102 FLATBED SPREAD AXLE (A53843)
2006 FONTAINE...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
Vermeer Chipper BC900 (A52377)
Vermeer Chipper...
PRINTER (A53843)
PRINTER (A53843)
