Can't lower 3ph 7010
   / Can't lower 3ph 7010 #1
Keltic
Bronze Member
Cape Breton Island
13 LS 7010C,91 Kubota L4150,Thomas 153S< Can Car C-4,BobCat 35E, BobCat 590,Pete 378 Tandem, Lots of other junk.
Hi, can't lower 3ph, something is stuck I think, I remember a couple of years ago the same thing happened and it was a simple fix, I just wiggled something or other under the cab, ( I think on the right hd side as you face the back of the cab) but I can't remember what! Any clues? Thanks, Fred
   / Can't lower 3ph 7010 #3
There is usually a "screw valve" that controls the up & down speed of a 3 pt. assembly with an attachment on it ( i.e. = Weight) If the valve is closed it locks the position & the more open the faster the 3 pt. will drop. Remember the 3pt on a tractor only lifts and the implement weight drops it. If no attachments are on the "speed valve" must be open and sometimes you have to stand on the arms to get them down.
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
500BBL WHEELED FRAC TANK (A50854)
500BBL WHEELED...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
John Deere 12' Grain Drill (A50515)
John Deere 12'...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
