Capabilities of L3400
   / Capabilities of L3400 #1
wykubotaguy
Bronze Member
Kubota L3400DT
Anybody else have a L3400. If so, what have you done with it. FEL max lifs, 3pt weight you have carried, maxium weight you have towed? Thanks:D
   / Capabilities of L3400 #2
I only have 30+ hours on mine so my experience is limited. I have 'plowed' snow with the fel curled back slightly on a 500' driveway this winter. I spread 50 ton of process stone on the driveway - I guess a full bucket is about 1000 lbs. I think the heaviest 3ph implement I have is a BX42 chipper. It certainly has no difficulty handling that small load (probably <500 lbs).
I did use a 5' boxblade to help clear / flatten 1/2 acre of wooded area. Other than catching a good sized root once it worked out great - I just go real slow around the trees :)
I also used the fel to push over small trees in this area (<3" diameter). Then the bucket is used to rip out the root ball.
So far it does everything I could want.
Thanks Ctgoldwing. I have moved approx. 150 yards of dirt, 24 yards of 3/4 minus rock, and tilled very little. The reason i was asking about max fel and so forth is i have never maxed it out and have had large loads (rear tires spin w/ tiller attached, i dump half of those loads. not worth breaking a front axle.)and i never seem to have enough traction. The rear tires are filled and the tiller weighs 700#. I am second owner of the tractor. Is it possible the previous owner changed the limit on the bypass valve and if so how do you change it back. thanks:)
2020 Kenworth T880 Tandem Axle Day Cab Road Tractor (A47384)
2020 Kenworth T880...
Killbros 1950 Auger Wagon (A50514)
Killbros 1950...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
20" Sea Container (A47384)
20" Sea Container...
JBAR PRM 5 5' ROTARY MOWER (A51243)
JBAR PRM 5 5'...
IH 480 18' Disk (A50515)
IH 480 18' Disk...
