s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,548
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
Due to two mild winters in a row and lower consumption of firewood, I didn't run my log splitter for over a year. I had run it dry and did annual maintenance before storing it in early 2019.
Yesterday I decided to split some wood from a maple that came down a few weeks ago. Got the splitter fueled up but before I could start the engine I noticed fuel dripping from the carb. My first thought was the carb float was stuck, since I have seen that happen before on stored equipment. I took off the bowl and the float appeared to be moving OK and didn't seem to have fuel inside it (say if the float had developed a crack). The bowl looked clean with no gum or varnish. Put everything back together.
I took off the spark plug and pulled the start cord a few times, which expelled a lot of fuel (and due to being a windy day, required a change of pants). Gave it 15-20 minutes to dry out and then started and ran the splitter just fine. But when I took a break later and dropped the engine to idle, it subsequently began dripping fuel again. Only when running at half throttle or higher would it not drip.
So I am coming back to maybe the float having a crack or leak in it that prevents it from floating up and shutting the fuel supply valve. Or maybe the supply valve needle/seat has some foreign object or gum that prevents it from closing. Any other suggestions?
This is a Kohler SH265 engine by the way.
