Carberator
/ Carberator #1
George49
Albuquerque, NM
1956 Farmall Super M Venturi
I have rebuilt the carb on my 1956 Farmall Super M but now for some reason the fuel isn't flowing correctly and it won't start on its own but will start if I spray carb cleaner into the carb. Also, does anyone know which way the carb venturi goes in? I'm thinking I may have installed it wrong.
/ Carberator #2
See if you can turn it around, wider side should be faceing out.
/ Carberator #3
I believe that the venturi will only fit in one way. Another thing I can think of why this is happening is that the choke is not hooked up correctly. Take the intake hose off and place your hand over it to simulate choking it. There should be a strong smell of gas there. If it tries to run and dies it is most likely a problem with the jets.
Mahindra Mforce 105p (A64126)
Mahindra Mforce...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2019 Deere 35G (A64126)
2019 Deere 35G...
20' CONNEX BOX (A65643)
20' CONNEX BOX...
