reb
Platinum Member
This isn't on a tractor, but it does relate to agriculture on a small scale. Besides, I don't know of a better place to get some free skilled advice.
I have a shredder with a B&S engine. After rebuilding the carburetor I have had some difficulty getting it to run. It now will run for 3 or 4 minutes before it floods out and stops. It looks to me like the float valve will not seal properly. When the carb is apart, I can turn the top assembly over and the valve does not allow me to blow air through it, but when it is assembled and installed on the engine it gets liquid fuel into the throat (it is an updraft carb). There is also evidence of gas around the gasket between the bowl and the top assembly. There is no apparent leakage from the bowl, around the main jet. I checked that with the carb apart. The float looks ok. When I take the thing apart there is no sign of fuel inside it.
I'm thinking that maybe the seat for the float valve is faulty. It is not a separate piece as in some carburetors, it is a hole in the casting. My next idea is to somehow attempt to lightly dress that hole to remove any small imperfection.
Anyone here had the same problem or have any ideas?
