Case 1816B Steering issue
   / Case 1816B Steering issue #1
copperdog
I have an older model 1816B that the warmer (operating temperature) it gets, the less agressive the left side drive becomes.
The right side works normal, left side needs some attention.
Is there anybody out there that knows how the system functions, it also has a noise in the system, like oil going over a relief. I have not installed any pressure gauges on it. There does not appear to be any test ports installed for such a purpose.
There are two pumps and two drive motors, I am assuming two individual relief valve assemblys also. When they built it, they compacted it into a small package, so major surgery is necessary to even look at the motors, let alone work on them.
   / Case 1816B Steering issue #2
You could have a weak motor as on most when warm is when the first signs of weakness will occur. I'd want a set of gauges on it to check it to be sure.
I got it apart and it appears as the clevis that turns the shaft that actuates the motor is worn, just slightly turns the shaft, I believe I got lucky.
It still has an oil leak, input shaft on the one pump, looks simple to replace, I won't get my hopes up. It still has an oil leak I am searching for that I can't locate. It looks like the entire pump drive assembly will come out as a unit?
2020 KENWORTH T680 SLEEPER TRUCK (A52141)
2020 KENWORTH T680...
2007 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2007 Ford F-150...
84'' Bucket (A47384)
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
Year: 2010 Make: Honda Model: CR-V Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A51694)
Year: 2010 Make...
1997 GROVE TMS750B 50' TON CRANE (A52141)
1997 GROVE TMS750B...
