Case 265 (Mitsubishi MT250) no fuel from pump.
   / Case 265 (Mitsubishi MT250) no fuel from pump. #1
ccaissie
Lincoln county, Maine
International B275
Just rebuilt the K3H, and am starting it. There is no fuel getting out of the pump after cranking it a LOT. Glow plugs are out to get it spinning fast.
Pretty sure the pump went back onto the block well, governor all that. Linkage to the shutoff was easy.
Anyhints on this sort of conundrum? I will pull the side linkage off and have a look inside...acts like the shutoff is engaged...not a drop of fuel. from the pump.
   / Case 265 (Mitsubishi MT250) no fuel from pump. #2
Go through the bleeding procedure to be sure you are getting fuel to the pump. These pumps have no capacity to suck, they must have fuel at the input to get fuel out.
44in Tooth Excavator Bucket (A51691)
44in Tooth...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
TEST YOUR BID BUTTON! (A51246)
TEST YOUR BID...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
