Case 446 Onan Engine Shrouds
   / Case 446 Onan Engine Shrouds #1
Dr Natedogg
74' Case 446
Is there anyone out there who has had any dealings with the 74' Case 446 engine shrouds. I'm trying to change the intake gaskets and replace the carb and it would appear I have to take apart the the whole back end of the tractor to get the engine shrouds off, am I missing something here?? From what I see I have to disconnect the lovejoy and all the mounting behind the dash and unhook just about every piece of pipe and electrical just to do this. It's all one piece except around the mufflers and even part of that is riveted which don't come off. I'm so frustrated that something would be designed this way. If anyone can help I would be forever in your debt.
   / Case 446 Onan Engine Shrouds #2
Hmmm No Response to this?
I'd like to replace my points and condenser,
but I can't seem to get at the bottom of the
Points/Condenser box because it's beneath
the engine shroud, which there doesn't seem
to be any way to remove???
Plus there a hard hydraulic pipe going across
the back of the motor, and another hydraulic
hose that are in the way!!!
What to do???
Thanks, Jim
   / Case 446 Onan Engine Shrouds #3
As I said in the other thread, talk to Boomer.
2008 FORD F-250XL SUPER DUTY EXT CAB TRUCK (A51243)
2008 FORD F-250XL...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
FELLA TH800 HAY TEDDER (A51243)
FELLA TH800 HAY...
