case 480b back hoe diesel extenda hoe 3,000 hours
   / case 480b back hoe diesel extenda hoe 3,000 hours #1
hamiltor16
Southwestern Ontario
YM195D and Zetor 8045 Case 580SK kubota 2320 fel
I am trying to get an idea what this machine is worth
any help would be appreciated
Rick
   / case 480b back hoe diesel extenda hoe 3,000 hours #2
Well the tlb season is now finally upon us,so the prices will be up. If it is clean,has a cab,good tires,runs well with out any leaks I'd say..........$10,000 or so frostbacks. Depending on the condition of course it could go either way on price.
thanks woodbeef
   / case 480b back hoe diesel extenda hoe 3,000 hours #4
With an extenda-hoe, if the prior owner abused it, you'd be into a large bill to re-build the slides on the hoe. I'd also check to see how much slop there are in the pivot pins, especially the fulcrum pin where the cast frame of the hoe attaches to the main body of the tractor (just below the operators station). I've seen them go around here for anywhere around 5K to 10K. A 10K machine would be well kept. 3000 Hours isn't alot, as long as the machine was greased and maintained in a reasonable manner.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
CONTACT INFO (A53084)
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
