case 480LL running problem
   / case 480LL running problem #1
BBQJOE
Wikieup
case 480 LL
Hi all! First post here. I'm baffled.
I have a fair amount of diesel experience, but I'm no diesel mechanic.
I have an older case 480 LL. It starts right up. Runs for about a minute at idle, not so long at full throttle, then dies.
If I let it sit a minute or so, it starts right back up, then dies again in a minute or so.
I suspected fuel filters, and replaced them both. Problem still exists.
Air filter dirty, but I've seen worse. Tried running it without the filter, same result.
Engine has oil, and water. Battery is good.
This appears to be gravity fed, and the return goes straight to the bottom of the tank.
I anxiously await your thoughts.
   / case 480LL running problem #2
Blocked outlet from tank ?
Blocked screen in liftpump ?
Blocked fuellines ?
Blocked screen at inlet to injecorpump ?
   / case 480LL running problem #3
Blocked return line..??
Cat 315l Excavator (A50514)
Cat 315l Excavator...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
MIDLAND POLY PIPE REEL TRAILER (A50854)
MIDLAND POLY PIPE...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2006-2009 Ford 4x4 Pickup Truck Bed (A49461)
2006-2009 Ford 4x4...
2018 INTERNATIONAL LT625 SLEEPER (A51222)
2018 INTERNATIONAL...
