Case 485 Bushhog not working after fluid Change!!
   / Case 485 Bushhog not working after fluid Change!! #1
WJSFarms
Rutledge, GA
John Deere 950, Case IH 485
I need help guys! I just bought a Case IH 485 Tractor. I tried it out before buying it and bushhogged about 1.5 acres. It did awesome. I bought it and changed the oil, fuel filters, hydraulic filter adn hydraulic fluid. Now when I bushhog and hit a big patch of grass the PTO stops spinning and it wont bushhog worth a crap. Like it is bogging down or like a hydraulic relief or something. Anyone know what may be the problem??
   / Case 485 Bushhog not working after fluid Change!! #2
Did you check the hydraulic fluid level after the problem? If the engine sounds like it is bogging down have you checked the fuel filters again? On my JD it has clear filter glass/plastic housing so you can see if they are getting clogged with major crud.
   / Case 485 Bushhog not working after fluid Change!! #3
I'd check to see if it has a slip clutch on the mower and that more then likely is your problem.
New/Unused Pallet Forks (A44391)
New/Unused Pallet...
2012 Chrysler 300 Limited Sedan (A44572)
2012 Chrysler 300...
2012 Chevrolet Silverado 3500HD Crew Cab Dump Truck (A44571)
2012 Chevrolet...
(4) Foam Filler Tires and Wheels (A44391)
(4) Foam Filler...
Dosko Stump Grinder (A45336)
Dosko Stump...
2013 Hyundai Trailer, VIN # 3H3V532C9DT026656 (A44391)
2013 Hyundai...
