case 7020 no reverse
   / case 7020 no reverse #1
max583
Stormville NY
case/ingersoll 7020, Deere GT235
I have a ingersoll 7020 that has no reverse at rear wheels.I have been reviewing all the forums I could find on this.
I replaced the balljoint,banana plate,most of the drive control linkage that looked worn. With it jacked up,I have forward at rear wheels,
but no reverse.with it in 4wd I only have rear wheel spine in foward and only front wheel spin in reverse. I changed the fluid and filter,everything else
works great,backhoe ,loader ,steering ,so pump pressure shouldnt be a issue.It has 500Hrs.Its a great tractor. Im getting frustrated :confused2:any Ideas ? Thanks
   / case 7020 no reverse #2
Did you work on the front diff ?
Sound to me the the front diff was assembeld upside down ?
No work done to the diff. Reverse at the rear wheels is a low power,almost none. In 4wd just the fronts work in reverse not in forward. Any problems with control valves ?
Finally fixed it.. Check valve for the hydraulic drive system stuck,took apart and freed up ,good to go.
4wd works ,and reverse working.
2023 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2023 SMITH...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
2021 Caterpillar 299D3XE Track Loader (A53342)
2021 Caterpillar...
2010 Chevrolet Malibu LTZ Sedan (A51694)
2010 Chevrolet...
