Case IH D40 temp gauge install
   / Case IH D40 temp gauge install #1
Big_Lug
Jennings,LA
Case IH D40
If anyone can reply it would sure be appreciated, how hard is it to install a factory original temp gauge for a D40. This tractor does not come with a gauge, just an idiot light, and I know I have to install the gauge in the instrument cluster, but the kicker is how do you wire it up? Just need a little explanation of this. Thanks to whoever responds.
   / Case IH D40 temp gauge install #2
It's possible the wiring is already in place. You'll likely need a new sending unit that will work with the gauge. I have a shop manual,I'll try to look tomorrow for some info.
   / Case IH D40 temp gauge install #3
Most gauges will include a sending unit with them. ALl you wil really need is a power source that is triggered by the ignition and a good ground.
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2014 Doosan DA30 (A52128)
2014 Doosan DA30...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
