Case ih mx 285 hydraulic remotes wont release
   / Case ih mx 285 hydraulic remotes wont release #1
Uffelmann
Red Bud, IL
CIH MX 285
When we put the hydraulic remote in detent they don't release... We have the timer set for 3 seconds and have the dial in the arm rest set to 1. Any suggestions on how to get this working?
   / Case ih mx 285 hydraulic remotes wont release #2
Not familiar with MX 285 hydraulics but on most systems With the valve in detent you applying pressure to the work ports which will make it next to impossible to disconnect the quick disconnects. Usually the lever is in the spring centered position and any and all weight is removed from any implement is removed before disconnecting the remotes.
   / Case ih mx 285 hydraulic remotes wont release #3
Sounds like the timer is not working. IRC on the 285 you can turn the timers off to run scrapers and vacs that require constant flow. A lot of times it needs to use the case dump on the return side to get max flow.
2013 Ford Focus Sedan (A50324)
2013 Ford Focus...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
1274 (A50490)
1274 (A50490)
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
2019 KOMATSU WA380-8 LOADER (A51242)
2019 KOMATSU...
