Case IH starter not engaging
   / Case IH starter not engaging #1
double hunter
Ford 1715
Just bought a Case/IH 255 at an estate sale, got a heck of a deal, anyway the starter is not engaging, it will spin but not engage the flywheel, been sitting up for a couple years, any suggestions as to what to check,
   / Case IH starter not engaging #2
I had that problem with my Ford.
Pull the starter, and check for rust on the bendix gear and shaft. You likely will be able to break the bendix loose, and it should work just fine. Perhaps a little WD40.
   / Case IH starter not engaging #3
Low battery, bad cables, bad connections will also cause the bendix to not throw the gear out all the way. Could be a weak starter too.
But as mentioned........take it off and clean and lube.
   / Case IH starter not engaging #4
Good point about the low battery or cables.
Tractors are often easy to touch the starter with (and selenoid) with jumper cables, although loaders often get in the way.
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A51039)
John Deere 1110...
