Case M160 mower (built by Woods I think) drive pulley question
   / Case M160 mower (built by Woods I think) drive pulley question #1
pjesson
Marvin, NC
Case 1120
I have a Case M160 belly mower under my Case 1120 compact tractor. I bought the whole rig second (or 12th) hand and have spent much of the last 2 years maintaining it. There always seems to be something wrong but it does seem to be gradually improving.
The latest problem is the drive pulley on the mower falls off. I have an "Operators Manual/Parts Catalog" for the mower. I think I am doing everything correctly but everytime I put it back together it just falls off again. I can't see what is supposed to keep the pulley on.
The shaft from the gearbox has a spline with a semi-circular key that fits in it. This fits into a spline in a "bushing" (part# 1993037C1). The bushing is tapered on the outside so that the pulley press fits around the bushing, then there are 3 set-screws that thread in between the pulley and the bushing. The manual indicates that the set screws are to be torqued to 14 ft-lbs.
The manual says:
Install drive pulley (2) with split tape bushing (1) on gearbox vertical shaft. Make sure key (4) and keyways are aligned.
Position centerline of drive pulley (2) 15/16" (plus or minus 1/32") above mounting surface of gearbox stand (3) as shown. This is a very critical dimension and must be held. Alternately tighten split taper bushing set screws to 14 ft-lbs. Check mounting distance to make sure it is correct.
I've tightened those set screws as tight as I can but the pulley/bushing combo just falls off as soon as I put power to the mower. It isn't obvious to me what is supposed to hold the bushing on. Just squeezing the shaft? The set screws don't seem to be trying to tighten the bushing at all...they don't look like they are tapered and in any case they bottom out before they put much pressure on the bushing to tighten. Maybe they are trying to move the pulley itself up the taper and thereby squeeze the bushing? In any case it isn't working because the whole thing is falling off again.
I would try buying a new bushing if I could find one but my searches indicated that the part number was replaced, and that neither the original part, nor the replacement part is available any longer. But the bushing (although not pristine) looks like it is in reasonable shape.
Anybody have any thoughts on this?
   / Case M160 mower (built by Woods I think) drive pulley question #2
The manual says:
I dont know if you figured out how to keep that pulley on but I had the same problem multiple times. I finally put it back together kind of like how case says however, I went on line to ebay and bought stud and bearing mount liquid from loctite. This locks gaps up to I think they said .024" , I put it on let it dry and havent had a problem since. They do say that if you want to take it apart you mite need to heat it to above 500f but I think its a small price to pay to keep that darn thing on longer than a few days! Phil
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2021 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A55852)
2021 Chevrolet...
Honda EM3500S Generator (A55851)
Honda EM3500S...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2015 FREIGHTLINER 122SD TANDEM AXLE DAY CAB (A56138)
2015 FREIGHTLINER...
Spirit scooter (A55787)
Spirit scooter...
