caseih 1845C
   / caseih 1845C #1
klm
Northwest MO
Allis D17 CIH D40, JD5310, Massimo MS50010
Never had a skid-steer but have inherited a 300 acre farm that needs a lot of cleanup, fence row cleanup, new fences, couple of old buildings to take down and lot of brush to clear. I keep hearing that a case 1845c is a good low budget simple reliable machine. My questions, I want to get a hydraulic brush hog and maybe a hydraulic post hole digger. Will this machine run them?
   / caseih 1845C #2
I have an older 1845c, the std aux hydrulics are 16gpm which will run a PHD without a problem and should be enough for a small bush hog. The optional high flow is 30+gpm I believe but I haven't seen many with the option.
They are a relatively simple machine and built solid, my electrical panel was gone when I bought it and I've heard they are problematic but I plan on just building a new harness and making an idiot light panel using the factory sensors.
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
KENWORTH T800 (A50854)
2018 INTERNATIONAL LT625 SLEEPER (A51219)
2018 INTERNATIONAL...
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
