Cast Iron
   / Cast Iron #1
MasseyWV
Veteran Member
After reading about tractors that have broke in half at or near the bell housing, which is typically made of cast iron or some other unobtanium material, I couldn't help but wonder why it is used instead of steel.
Cast iron is a very strong metal but it is brittle and can crack or break without warning, as evidenced by some tractors breaking in half. Also, cast iron is difficult to weld, thus making repairs impractiical or impossible.
I am no metallurgist but it seems to me that steel would be a much better material to use. Steel is very strong, more flexible, and can be easily welded, thus making repairs much easier.
Engine blocks I can understand, but why do tractor manufacturers use cast iron instead of steel for bellhousings, axles, and other components?
   / Cast Iron #2
Steel would probably be better than cast iron, but it would have to be mostly machined to form up such intricate parts such as a transmission tunnel or a bell housing. The cost to machine such parts would be exhorbitant, which would drive up the cost of tractors significantly. It's much cheaper to make such parts out of a cast metal, then do some finishing machine work to get smooth surfaces, angles, and precise holes where needed. At least, this my take on it from what I know of metal working.
   / Cast Iron #3
There is actually no such thing as cast iron. Cast steel is more apt. The alloys can be all over the place to give it different properties.
   / Cast Iron #4
No such thing as cast Iron? That news to the metallurgy world :D
   / Cast Iron #5
Main reason is the cost of manufacturing as was mentioned, but also the cast iron has a property you hit on without realizing. "MORE FLEXIBLE" is not good when it comes to some parts. Cast iron typically has very little bending whereas steel will bend more readily. Even some very minor bending when loading/stressing will equate to problems in the very near future when it comes to bending it back and forth. Using a metal that doesn't give till it is time for it to fail and then overdesigning that part will give you excellent results. Since the parts you mention typically have bearing surfaces and low tolerance part movement designed in them, having a part that the metal moved would most likely not be good. If a transmisson case bent as you loaded the bucket, can you imagine what that would do to the clearance on the gears as they meshed or the alignment of a shaft?
I think the best idea for a continued one piece tractor would be a sub-frame like is usually recommend on a backhoe. I know if I ever put a loader on a tractor, I am going to seriously look at reinforcing it with a subframe.
David from jax
   / Cast Iron #7
Maybe the alloy currently being used to make magnet attracting tractor parts from using a casting procedure can be called the metal in question of the O/P.
David from jax
   / Cast Iron #9
huh? Cast iron is in the same class as "unobtainium"?
Cast iron is one of the most utilized structural materials combining
incredible design flexibility, high strength and low cost. Parts that crack, are typically from poor design or the use exceeding the design spec. Backhoes are typically in that category by the way unless a STOUT sub-frame is in place.
Manual Excavator Thumb (A44391)
Manual Excavator...
Lincoln Electric Square Wave Tig 255 Welding Machine (A44571)
Lincoln Electric...
2022 John Deere 8R 340 Row Crop Tractor (A46878)
2022 John Deere 8R...
2016 Dodge Charger Sedan (A44572)
2016 Dodge Charger...
2018 Ford F-150 Pickup Truck (A44572)
2018 Ford F-150...
2020 Chevrolet 3500 4x4 Utility Truck, VIN # 1GB4YSEY3LF346182 (A44391)
2020 Chevrolet...
