Casters make removing MMM or rear BB a breeze...
   / Casters make removing MMM or rear BB a breeze... #1
KeithInSpace
Veteran Member
Fred'burg, Virginia
Kubota BX2230
Just a tid-bit...Lowe's sells these little trinaguar low-rider casters for $7 a piece...imagine a little bitty auto-creeper with only three caster wheels connected to a rubber-coated metal cup in the middle. They are rated for something like 200 lbs each.
I position 4 of them under the outer anti-scalp wheels of the deck and lower the deck onto them. Pop the shaft and the over-center rig in the front and just slide the whole thing out the side. Then you are free to wheel it wherever you like (if you, of course, remove it in your garage or a similarly smooth surface), greatly increasing the storage possiblities.
I also have 4 under my 4' BoxBlade and 4 under my aerator simply for the sake of not killing myself moving them around. Now I can just line them up against the wall until needed.
Haven't figured anything out for the FEL yet.
   / Casters make removing MMM or rear BB a breeze... #3
Someone here uses the furniture moving castors available at home depot for the FEL.
   / Casters make removing MMM or rear BB a breeze... #4
   / Casters make removing MMM or rear BB a breeze... #5
I can't mentally picture this, can you post a pic?
   / Casters make removing MMM or rear BB a breeze... #6
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
American Sanders Super 7R Electric Wood Floor Edger (A49461)
American Sanders...
Nissan 5k Forklift (A51039)
Nissan 5k Forklift...
