Cat 1 implements with 9540 or 7040?
   / Cat 1 implements with 9540 or 7040? #1
UncleBuck1
Baton Rouge, LA
2011 MF 2660HD; 1964 JD 4020 (may she rest in peace)
I'm shopping for a tractor and have come across two Kubota's- a M7040 and a M9540- that I really like. The problem is, the spec's for both tractors say that the 3 point hitch system is Cat. 2 only. Most of my implements are Cat. 2, but I have a set of United 24x20 discs that have standard Cat. 1 pins; it wasn't a problem on my old tractor, a JD 4020, because you could reconfigure the sway blocks for the difference in width between Cat 1 and 2. It was a pain, but at least it was adjustable.
Bottom line, is it possible to use Cat 1 implements with one of the Cat. 2 only Kubota's?
   / Cat 1 implements with 9540 or 7040? #2
I assume the the hitch on the disk is not adjustable for width...
That is correct, it has standard Cat. 1 lift arms bolted into the frame. The lift arm dia. issue is easily addressed with bushings, what I'm trying to figure out if the lower arms on a M9540 or M7040 will swing in tight enough.
When I looked at the tractors I didn't think to measure min. width or study how Kubota controls lower arm width (stabilizer bar? sway blocks? chains?) and whether it was adjustable.
   / Cat 1 implements with 9540 or 7040? #4
I nearly bought a M9540 after I bought my L5740. Never looked to see if the 95 lift arms would go close enough together for cat1 implements. I'm no help...
   / Cat 1 implements with 9540 or 7040? #5
They should be okay!
   / Cat 1 implements with 9540 or 7040? #6
I have a M7040 and use a lot of CAT I implements with no trouble at all. The "check chains" are telescoping so adjust easily.
You do need to put CAT 1 to CAT 2 bushings on the implement so they pins are large enough to fit tightly on the tractor. The bushings are less than $2 each at Tractor Supply or any tractor dealer.
   / Cat 1 implements with 9540 or 7040? #7
You can hook it up fine. Although I mostly use my M9540 with a batwing cutter, I have had cat 1 attachments on it.
   / Cat 1 implements with 9540 or 7040? #8
What they said, you have a lot of adjustment and we too have used cat one on our M8540 and previous Case CX80.
   / Cat 1 implements with 9540 or 7040? #9
As stated cat l implements will attach to 3 pt hitch with the aid of bushings on the Kubota tractors mentioned a lot easier that turning the sway blocks on the 4020. I frequently use Cat l implements on my M7040
   / Cat 1 implements with 9540 or 7040? #10
I think you'd just shim your Cat2 down to Cat 1 with standard SpeeCo shims and hook up.
2019 Nissan Versa Sedan (A46684)
2019 Nissan Versa...
2008 Thomas Freightliner 71 Capacity School Bus #29 (A49339)
2008 Thomas...
Vermeer M7040 Disc Mower (A49339)
Vermeer M7040 Disc...
2025 Swict 78in Bucket Skid Steer Attachment (A46683)
2025 Swict 78in...
12'x20' Galvanized Metal Livestock Shed (A43476)
12'x20' Galvanized...
2015 Chrysler 200 Sedan (A46684)
2015 Chrysler 200...
