CAT 257 hydraulic tilt will not hold
   / CAT 257 hydraulic tilt will not hold #11
Well Roy, I finally disconnected the hydraulic lines going to the tilt cylinder, capped & plugged the ends and started the machine up & raised the bucket in the air...and the bucket held its position. I raised the lift arm to put the bucket about 3' off the ground & let go of the controls, let it sit for a good 30-60 seconds and the bucket did not limp down. So I guess that means the cylinder is good, any idea what else it could be? Again, I already changed the relief valve at the hydraulic bank under the cab & unless I changed the wrong valve, that didn't fix the problem. Thanks again for your help so far.
Has anyone found a solution for this? I would greatly appreciate any feedback
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2015 Mitsubishi Outlander Sport SUV (A53424)
2015 Mitsubishi...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
Bridgeport Milling Machine (A53117)
Bridgeport Milling...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
