Cat 257B hydraulic fan cutting off
   / Cat 257B hydraulic fan cutting off #1
gTrees$
257B Caterpillar 2010
Is there a sensor somewhere that would cause this to be happening. Hydraulic fan cutting off
   / Cat 257B hydraulic fan cutting off #2
I suspect that fan runs on a temperature sensor but I have no clue where it is located. Is there a separate fan for engine cooling or the same fan?
   / Cat 257B hydraulic fan cutting off #3
Typically proportional hydraulic fans have a “fail full on” logic in the design. This means that if the power is cut to the proportional control valve, it will default to full fan speed. If you can find the proportional valve that controls the fan, unplug the electrical connector and see if you get full fan speed. If so, then it will lead you towards an electrical issue. If it doesn’t, then it would be something hydraulic. Most likely you have a sensor that is failing but this simple test will help verify that a sensor is the culprit.
2012 WABASH 53FT DRY VAN TRAILER (A52576)
2012 WABASH 53FT...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
New/Unused 10ft Workbench with 30 Drawers (A51573)
New/Unused 10ft...
