CAV DPA Timing Problem
   / CAV DPA Timing Problem #1
yacht coho
Westerbeke W46
Thank you for reading.
My CAV DPA was leaking badly.
I removed the pump after photographing the timing mark and circlip.
Manual said the timing gear would hold in place but I think the gear may have moved one tooth, my bad but not certain.
Second problem is the diesel shop did not leave the circlip in position.
Pump is in and engine starts well. Rough at lower rpm. Smooths at half but not as before. But smoking white diesel at all speeds.
I think timing gear is 33 teeth (10.9deg per tooth). Mount has about 5 Deg swing and probably 3 to 4 Deg off.
In Colombia enroute Panama and all shops are Spanish speaking.
Plan. Get access to CAV DPA by stripping aux pieces.
Move timing gear one tooth CW. Flange on scribed marked. Start engine.
Move timing gear one tooth CCW (from original position). Start engine.
Question. Will the engine run if timing is 1 tooth or 10.9 Deg off?
Thank you for any assistance.
   / CAV DPA Timing Problem #2
U didn’t mention the engine or tractor Mdl..
I asked more questions on the Tractor Forum thread.
Thank you. Answered on the other Forum
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
Ford Tractor (A50120)
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
2012 Chevrolet Silverado 3500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
