Chained Bushhog
   / Chained Bushhog #1
RSKY
Veteran Member
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
Was cleaning out a fence row at the oldest daughter's house. I would cut the bigger trees close to the ground and drag them with a chain on the bucket to put them in an old pond.
Unchain them and throw the 20' log chain on the mower deck and go back for another. Have done this for thirty years with the old tractor and mower. After an hour or so I had a strip cleared enough I could mow over the area. Luckily I had the tractor idling when I engaged the pto. I heard that chain rattling and clutched it just as the chain tightened up. You know those little holes in the deck of all the new rotary mowers have a hole so you can get to the bolt that holds the blade on the stump jumper. Well a chain rattling around on the deck as you drive across a field will find that hole and catch on the stump jumper bolts. I know I'm not the first to do this but thought I would warn others.
   / Chained Bushhog #2
I cut a steel plate to put over mine. I drilled two mounting holes in the deck and stuck bolts through from the bottom and tack welded them so I can easily remove the plate without having someone else to hold the back side of the bolt.
   / Chained Bushhog #3
Dang , Now I know what that circle plate is that is bolted on the upper side of my N.H. "hog" :) . Seriously , Great catch , not sure if you have a slip clutch or like mine a shear bolt . Nothing like breaking a shear bolt , "THEN" realizing you already used your last one , and now have to make a trip to town for more .:ashamed: ( You don't need to ask why I mentioned that .:( ) .
Honestly , never had to use that plate yet , did not even know what is was used for , just knew it was there .
Fred H.
   / Chained Bushhog #4
I sort of did the same thing except that I used a single bolt and a nyloc nut tightened just enough to hold the plate in place snugly and I simply rotate it to access the blade bolts.
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
