chainsaw
   / chainsaw #1
PeterT
Bronze Member
central Indiana
JD 4610
Anyone know why a craftsman chainsaw will not oil the bar? What pumps the oil out to the bar?
Thanks Petert
   / chainsaw #2
oil pump I believe.
Basic, but have you taken the bar off and cleaned out the oil holes?
   / chainsaw #3
On the back of the saw, there is a lever about one and a half to two inches long. Every time you press this down, some oil will come out to the blade on the lower side.
   / chainsaw
Thanks guys. I took it apart today, took the clutch off and a small side cover and what looks to be the oil pump off. no oil would come out of the tank to feed the oil pump so I shot a blast of air in there and it opened the flood gates. Cleaned it all up and put back together and it seems to be working fine for now. I may have to do it all over again as I blew air back into the tank and proably whatever was pluging it up back into the tank.
Thanks again
Petert
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
WOLVERINE PAB-11-72W HYD QUICK ATTACH ANGLE BROOM (A51244)
WOLVERINE...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
10' Feed Bunk (A50515)
