I have one of the 14" and one of the 18" saws, (wood shark and wild thing respectivly) the wood shark 14: is a great running machine in fact I used it yesterday after 2 months setting unstarted. it took a few pumps of the primer and the choak setting on to 3/4 and the 3rd pull she was running. it is 3~5 yrs old now. it was a Kmart close out when the store was going out of buisness I paid $47 for it, and should have bought both of them that was seting there! I LOVE it. it starts & runs like a champ cuts well and is light enough to cut using 1 hand at arms reach. (ya shouldn't do that I know but works wonders for limbing stuff out!.) I used it to clean up some ICE damage we had (today after wook I have 3 or 4 more big limbs down to deal with (poor pines are taking a beating) and it was very early on in this current ICE STORM. I imigine I'll have some POLES before this is all over! so far 3 of the 5 have the north sides compleatly broken away! little more than a few straggly branches left /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/crazy.gif
anyhow I figured they were talking about this ice storm comming so I figured I better clean up SOME of the limbs ust in case the trees got hammered more and they are... I can't do much with the damaged fall out as the yard is more of a swamp than tractor supporting clay...
anyhow the 18" wild thing has nearly same engine as the woodshark 14" so I'm not as impressed with it, (wallyworld special of 139.00 I think with case & extra chain. chains and bars are easy to find for the 18" but the saw tooth design on it is poor (has an odd number of teeth so you have two right hand cutters next to each other. which is bad unless you like cutting circels out!) it is still light enough to use for limbing and trimming and the added blade lenght is good for less bending. I use BOTH as they are only saws I have. I've been looking for used STHILS but the price is too high and NEW is very high in my low money budget.
mark M /forums/images/graemlins/smile.gif
