Challenger mt 275 or MF 1440????
   / Challenger mt 275 or MF 1440???? #1
cormier
Bronze Member
New Brunswick Canada
Challenger MT275
When checking the hydraulic oil level does the tractor need to be running or stopped on the Challenger mt 275 or MF 1440??? Its the same tractor that's why i am asking for both. I don't have a service manual to look it up.
   / Challenger mt 275 or MF 1440???? #2
Can't say for sure on your particular tractor. However, in every tractor I've ever owned, I always check with engine off and rams collapsed. (IE for example loader fully on the ground if you have one) generally speaking, I liked to check all the fluids before I ever start the tractor up for the day. That includes engine oil, engine coolant, fuel supply, hydraulic fluid, transmission fluid if it is seperate from the hydraulic fluid, and so on and so forth. Lot less chance of running low on something and ruining an engine or transmission.
   / Challenger mt 275 or MF 1440???? #3
I have the MT285b, I check with the hydraulics in, power off, and like to see over half up the sight glass on the rear end.
1996 Elgin Pelican Series S Street Sweeper (A50322)
1996 Elgin Pelican...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2007 Ford Edge (A50324)
2007 Ford Edge...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
Kubota L503OD 50HP Utility Loader Tractor (A50322)
Kubota L503OD 50HP...
