change hydraulic oil on 3600
   / change hydraulic oil on 3600 #1
gil1
ford 3600
I want to change the hydraulic oil on my ford 3600, but can't locate the drain plug or where to check the level.
   / change hydraulic oil on 3600 #2
Drain is at the bottom center of the rear axle center section housing. Fill plug is at the toop of the same housing next to the draft control spring housing. Level plug is a 1/4" pipe plug with either a male head or female hex located behind the right footrest and at nearly the same level.
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
2021 Harley-Davidson FLHP Police Electra Glide Motorcycle (A51694)
2021...
SET OF (4) NEW 11R24.5 TIRES (A53843)
SET OF (4) NEW...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
