Changed the front diff oil--looked like atf fluid
   / Changed the front diff oil--looked like atf fluid #1
cfoxmd
North of New Orleans
FX28D
today I was changing the front differential fluid on my FX28D. It was red when it came out--just like the hydraulic fluid (which now is 303). I put 90w gear oil in. Do they all come from japan with ATF in everything?--assuming it was atf.
   / Changed the front diff oil--looked like atf fluid #2
cfoxmd,
Yes, many come like that. Tractors that have clean, full fluids often don't get serviced once they are unloaded here (U.S.).
Mark
hmmm...that means I'ver run it close to 2 years with ATF in the hydraulic system and front differential. I thought ATF fluid was about a 10 weight oil, hydraulic fluid (JD 303) 20 weight and gear oil 90 weight. I guess that would make it more likely to leak from the diff, and maybe wear a little more because the oil would run off the gears more quickly. I guess my tractor didn't get fluids changed when it came to the dealer (or they put the ATF in).
   / Changed the front diff oil--looked like atf fluid #4
There was a discussion here a while back about fluids in diffies. Many dealers reported using ATF as that is what their importer told them they used.
It was also pointed out that ATF has hyd properties.. and lubricating qualities and is designed for some gear to gear contact... though I'm not sure it was meant for ep duty where a true gear oil ( hypoid) or even a multipurpose transdraulic oil would work.
I do believe I have seen some multi oils with red die.. not sure what brand but it was a 303/hygard/134d equivalent type oil.
Soundguy
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2015 Ford Econoline Box Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
