Changing a bearing seal on a King Kutter Rotary Mower
   / Changing a bearing seal on a King Kutter Rotary Mower #1
AndyF
Bronze Member
Central NY
Kubota B8200 & B7200
Our 6' KingKutter Rotary Mower needs a new seal on the gearbox. We've taken the blades off and haven't been able to get the Stumpjumper/blade carrier off the shaft. The shaft looks like a splined shaft. We don't see signs of a pin holding the blade carrier onto the shaft. So far we can't get the blade carrier to budge. We've tried hammering it off, using a pry bar to lever it off and finally my son made a puller with a 7/8-9 screw which he welded onto the blade carrier to try to drive the blade carrier off and even with a large cheater he was unable to get the carrier to budge.
What's the trick here? About the only thing we haven't tried is using a rosebud to heat the heck out of it while trying to pound it off.
   / Changing a bearing seal on a King Kutter Rotary Mower #2
Put a lot of presure on the puller and a lot of heat on the stumpjumper. It will come loose.
ron
Well I put enough pressure on the puller to tear the stumpjumper apart and didn't even move it a little bit on the splined shaft. The next step will be to get the torch out and finish cutting the sheetmetal portion of the stumpjumper off and see what I can do to get rest of it off. It isn't looking good right now for even being able to salvage the gearbox.
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A54607)
2016 INTERNATIONAL...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
SEPERATOR (A53843)
SEPERATOR (A53843)
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
