Changing drive belt 214 jd procedure
   / Changing drive belt 214 jd procedure #1
REt92
JD 1010 JD 3005
What has to be removed to change main inner drive belt on this tractor
Ret2
   / Changing drive belt 214 jd procedure #2
Was hoping that someone would chime in here that can give a good answer to your question.
Google changing drive belt on 212 as same as 214.. a few hits that may help.
It is the belt from engine to variator No mention of this belt anywhere as to removing it. It is buried behind the other belts
Ret2
   / Changing drive belt 214 jd procedure #4
I have a PDF of the tech manual if you want it, shoot me your email
Joe
   / Changing drive belt 214 jd procedure #6
on the way
Got it and really is a good manual. Thanks for sharing it I lived about 5 miles from Bascom for 30 years , in MiIlpitas.
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
2021 TAKEUCHI TL6R SKID STEER (A51242)
2021 TAKEUCHI TL6R...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
