Changing from power adjust rims
   / Changing from power adjust rims #1
glinka
Lansing,Mi
MF 65
I have a diesel MF 65 with power adjust rims that are rusting out. The tires are 13.6 x 38, which I'm told would be on a 12 x 38 rim. Can't find any used in good condition. Buying new runs around $450 per rim. I need both replaced. A regular rim is $175. What is involved going from one to the other, is it possible?
   / Changing from power adjust rims #2
Where on the rim are they rusting out? Ken Sweet
They re rusting mostly at stem areas, bad.
   / Changing from power adjust rims #4
I have seen a rusted rim have a plate welded over the stem hole,,,
then,,, drill a new hole at a different location,,,
   / Changing from power adjust rims #5
That procedure is pretty common and works well at almost zero cost. Ken Sweet
   / Changing from power adjust rims #6
Yep. Grind it smooth on the inside so the patch doen't tear the tube.
   / Changing from power adjust rims #7
I have seen a piece of old inner tube cur to cover the patch on the inside. Then, the new tube will not be in contact with the irregular patch surfaces. Ken Sweet
   / Changing from power adjust rims #8
I had rusted out valve stem holes on my IH. I welded washers over the hole and used the washer hole for the new valve stem hole. Has worked now for 14 years.
2025 40 ft. High Cube Shipping Container (A47484)
2025 40 ft. High...
40' 6 Door Container (A45336)
40' 6 Door...
TOFT 1000 Hyd Breaker Hammer (A47809)
TOFT 1000 Hyd...
2011 Vermeer 504MCL Round Baler (A47484)
2011 Vermeer...
Skid Steer Bale Spear (A47809)
Skid Steer Bale...
Agriquip 40' Shipping container (A47809)
Agriquip 40'...
