Changing Hydraulic Fluid on Massey 492 4WD
   / Changing Hydraulic Fluid on Massey 492 4WD #1
massey492
Huxley, TX
Massey Ferguson 492 4WD
I am attempting to change the hydraulic fluid on my MF492. I have the operators manual and it calls for removing the two drain plugs for the hydraulics. I have located them and thats not a problem, however, the 492 is 4WD and the manual says to open the drain plug fitted on the "front axle actioning case". There is a diagram but I can't make heads or tails of it. Any help would be greatly appreciated. Thanks.
   / Changing Hydraulic Fluid on Massey 492 4WD #2
Not looking at the axle, I would guess that there is a plug in the bottom of the differential, which should be the lowest point of the axle. .
LOT: Welding Accessories: (2) Auto Darkening Helmets, Welding Rods, Welding Wire, Magnetic Arrows (A59076)
LOT: Welding...
CFG Industry MX12RX Mini Excavator (A57149)
CFG Industry...
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
16' Farm Cart (A57149)
