changing hydraulic/transmission fluids
   / changing hydraulic/transmission fluids #1
gerard
Veteran Member
Syracuse NY
Kubota L2500DT w/FEL
I'm ready to do my 50 hr change of all my fluids and had a question on the hydraulic/tranny fluid. Will dropping all the drain plugs fully drain the system all will some fluid be trapped in the loader cylinders? If fully drained I assume when I use it the first time it may take a few seconds for the loader to respond until the cylinders refill? I'm switching to amsoil (Feel free to answer this one Mark!) and was concerned about the residual fluid mixing with the synthetic.
   / changing hydraulic/transmission fluids #2
Gerard - I wouldn't worry about the left-over oil mixing with the synthetic. It won't hurt anything, with the quatities you're dealing with. To minimize the amount of fluid left in the system, you can retract all the cylinders.
Mark
   / changing hydraulic/transmission fluids #3
Does that mean 3 point down or up to get most fluid out?
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59905)
2005 INTERNATIONAL...
2002 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2002 FORD F-350 XL...
2014 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2014 KOMATSU...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
