Changing Tire/Rim Size
   / Changing Tire/Rim Size #1
Dunacn
Furlong
Kubota L3010, Ford 4000SU
I have a 3cyl 4000su with 14.9-28 Ags in the rear. I have the opportunity to pickup nearly new 18.4-16.1 turf tires and rims on the cheap. I have basically retired this tractor to flail mowing about 10 acres of grass and the turfs would be nice. I believe these rims/tires were from an Ford LCG tractor. I know this isn’t an ideal setup, but it gives me something to do. Outside of finding some shorter tires for the front to level things out, is there anything that I would need to do to run this setup?
Thanks!
   / Changing Tire/Rim Size #2
Since that model appears to be two wheel drive you should be good to go with whatever size you put on the rear.
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
2020 John Deere 1025R MFWD Compact Tractor (A56435)
2020 John Deere...
2000 FREIGHTLINER CLASSIC (A58214)
2000 FREIGHTLINER...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
