Changing wheel bearing on RFM
   / Changing wheel bearing on RFM #1
homeinwestIL
Bronze Member
western Illinois
1968 gas Ford 3000
One of the gauge wheels in my Landpride 2572 RFM has seized up, so I assume that the bearing is bad. I'm trying to get to it to the bearing, but would like suggestion on how to remove the outer cover to get to the bearing -- #1 on the attached diagram. Anybody done this before?
   / Changing wheel bearing on RFM #2
So you have the heavy roller bearing which is good. you need a long punch to push out the far cap and then the bearing should fall right out after you remove the wheel from the hub.
Use a very thin flat screw driver to pry the cap off and then you can use the long punch if needed. These heavy roller bearings are really nice.
2008 Chevrolet Suburban SUV (A51694)
2008 Chevrolet...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
1998 FORD CRANE (A52472)
1998 FORD CRANE...
FIRESTONE 20.8R42 REAR TIRES WITH WHEELS (WHEELS FITS GENESIS TG-T8000 TRACTORS) (A52748)
FIRESTONE 20.8R42...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
