Charging battery
/ Charging battery #1
duck76073
kioti
Battery will not charge on vehicle. Removed battery and put on bench charges ok. Charging on vehicle the negative post gets extremely hot and discharge the battery. Help
/ Charging battery #2
Sounds like a poor or high resistance ground while on vehicle - maybe.
/ Charging battery #4
If the post gets hot, it is probably a dirty connection on the post.
/ Charging battery #5
Probably your negative ground, but I'd check the ignition switch, too.
My 2025R had a small electrical leak in the starter relay that cooked the ignition switch and caused corrosion on both battery terminals.
/ Charging battery
Thanks a lot for all the comments
/ Charging battery
The battery is on my Chevy pickup. The charger negative terminal is what gets hot and shows to be discharging after 30 minutes.
/ Charging battery #8
Voltmeter? Battery should be 12.5 0r so and should be 13+ when runnimg. Leave your battery un hooked for a while and see if it holds a charge. 12.87 is what my meter reads on a good battery. It should be the same, hours later.
Don't disconnect battery while engine is running on the newer vehicles. That's a no no. Old ones it's okay to do that, new ones not. By old ones I mean before fuel injection.
Preliminary Listing / Full Catalog Coming Soon! (A60462)
Preliminary...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2020 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2020 Kubota...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
2020 DRAGON ESP...
