kc5dlo
I recently purchased a Case 570LXT and while going over it waiting for the ground to dry a little, my neighbor and I noticed that when the tractor is first started, the tach does not register and the voltage stays at battery voltage. A blip of the throttle will get it to charging. Neighbor suggested changing the alternator. Found a new one cheap enough and bought it. We put it on last night and it wont charge at all.
The alternator is a Bosch type with a B+ terminal, a smaller D+ terminal and a spade connector for the tach. While looking online for the alternator, I came across a post that someone pointed out that the alternator light is what energizes these alternators and I don't see an alternator light on the dash. The lens on the dash needs replacing or polishing to see better but I don't know if there is an alternator light on this or not. There is an oil pressure light that is working and comes on when the key is turned on and goes off as soon as the engine starts. Tried taking the new alternator to AutoZone and O'Reilley's last night bot the people at both places looked like they saw a ghost when I told them the alternator was for a tractor and said they could not test it.
Worst case is I could live with knowing that I need to give the throttle a blip after starting to get the charging going but thought I would ask here about the alternator light and anything else I might be missing.
Steve
Steve
