Charging light staying on JD 750 compact
   / Charging light staying on JD 750 compact #1
steh
Covington, GA
1985 JD 750 Compact / 410 JD Backhoe
I had a electrical problem with my 1985 JD 750 compact tractor. The voltage regulator went bad and it burned both the wires going to the alternator at their connection point. I repaired the wires by cutting out the bad section and putting new connectors on. Then I replaced the voltage regulator. The tractor now starts fine but the charging light is on all the time, even when the key is turned off. I have to disconnect the positive battery post to get it to go off. I also check all the wiring, I could, to see if there was another frayed wire that might be touching the frame, but could not find anything. Could it be in the key switch and not disconnecting somehow when turned to the off position, but the light does stay on even when tractor is running?Any idea as to what to check next or what the problem might be?
   / Charging light staying on JD 750 compact #2
Check the voltage on the battery when its running,
your alternator may need to be replaced also.
   / Charging light staying on JD 750 compact #3
Skyhook is right, i have 850 jd just had same problem new alternator fixed it
2010 Cadillac SRX SUV (A50324)
2010 Cadillac SRX...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
John Deere 637 Disk (A50514)
John Deere 637...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
International 133 6 Row Cultivator (A50514)
International 133...
100 gal Water Tank (A50515)
100 gal Water Tank...
