charging system
   / charging system #1
fidler01
Jane Lew WV
john deere 2320
Does anyone know if they are any manufacturers that make a alternator for a case 430 diesel with a tach drive? all help appreciated. Thanks fidler
   / charging system #2
Never heard of a tach drive on an alternator, heard of them on a distributor. Why would you even need a tach on a alternator?
   / charging system #3
If you locate one you may need the associated tachometer. I think it counts pulses which would depend on the alternator speed. Of course the alternator speed is governed by its pulley and you need the correct ratio between the main pulley and the alternator pulley. You may need to do a bit of homework on this one.
   / charging system #4
I feel your pain. The generator on my Ford 3550 is set up the same way. I converted it to a GM alternator and now can not run my proof meter. Which was missing when I got the machine.
Hyster H225E (A47384)
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
71066 (A49346)
71066 (A49346)
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52128)
2022 New Holland...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
