If you want to pressure wash it, use LOW pressure. 25 yr old standing seams usually get very weak near the bends(seams). Best to find some help and use stiff brush on broom handle with TSP (trisodium phosphate), you can find at any hardware store. Then rinse well 2 or 3 times with just the hose, NOT high pressure. Let dry then you should recoat the roof with a fibered aluminizer coating, specifically for metal roofs, with paint roller.
This is a very affordable 'old school' technique, but because the fibered aluminizer is so thick it will add strength and many more leak free years to the seams. Make sure the roof is DRY!
I'm speaking of true standing seam where the 2 sheets are turned over together and the seam is no more than about 1/4" - 3/8" wide.
If you have a batten roof where the standing seams are 1" - 2' wide or more, a separete cap(batten) sits on the two sheets, then this would not be the technique to use. Post a pic and I may be able to give you more info. What material is it made of? What manufacturer? More info would be helpful.
