I'm changing the hydraulic fluid on my lift, I need hose to run from the suction side on the pump into a pail of hydraulic fluid. I'd rather not spend $5 a foot for hose that's only going to be used for about 15 minutes. I think even tygon tubing would work for this if I could find it in the right diameter in small quantities. It has to press onto hose barbs that measure 15/16" across the outside of the barbs, the existing hose measures 1-1/8" OD but it's European so it's probably some metric size. I need two pieces about 3' length. I've looked online but the number of types of tubing is mind numbing and it's often sold in large quantities. Thanks for any suggestions.
